Durval wrote:
Further tests:
There seems to be a precise difference of level that makes the problem occur or not.
If the difference of level is equal or smaller than 1790 mm, it works. (i.e., zones are correctly associated to windows)
If difference of level is 1791 mm or bigger AND there is a story below the one where the zones are, then zones are not associated to windows.
-Did you check the elevation and height of your zones?
-Are the zones auto zones or hand drawn ones>do they all join the surrounding walls properly?
Doing multiple buildings on different levels in one site is a lot of fun...
If the scale of the project allows for a bit more admin time, I would normally have the different buildings in separate files (pln or teamwork) and the site / landscape is a separate file again. Then to get overall site models, you can hot link module the different buildings into the landscape model, and may place the landscape draving as a drawing underlay into all different building's model. (This way you can always have site context in the separate buildings but the site context is a 2D drawing only) To set up levels in your site file would require some play around. Alternatively you may even save each building block as an object and place them that way to the site...
Scheduling though may need to happen building by building...
Karoly
ArchiCAD since 4.5
Windows, Mac
