Schedule of COMPLEX PROFILES
alemanda
Is there any way to have the schedule of the used/chosen complex profiles in a project with the graphic section of the profile?
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
Tim Ball
You could create a separate pln with all you complex profiles then set up a section view with them all nicely arranged and labelled. Then use that as an external reference into your main pln file as a kind of legend
Tim Ball
AC26, iMac
User since V5
alemanda
In order to have all in one file your workaround can be applied also to a floor of the building, in a remote area.
Thanks
AC27 latest hotfix
Win 10 Pro 64bit
www.almadw.it
