Schedules and 3D view
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2019-07-16 08:10 PM
‎2019-07-16
08:10 PM
I have a question regarding schedules. Some of the types of doors are not possible to view in 3D (I use that often for edition purposes). It's not only one type, several of them are not 'clickable'. This is teamwork project, so everything is reserved.
All the best,
Karol
OPENBIM does works!
ArchiCAD 22/23/24/25/26/27 INT &POL
AMD Ryzen 7 3700X, 128GB RAM, GeForce RTX 3070, Windows 11 Pro
MBP 14 M3 Max 16C/40G, 128GB, 2TB
http://www.bimfaktoria.pl/
Labels:
- Labels:
Data management
7 REPLIES 7
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-07-22 04:37 PM
‎2019-07-22
04:37 PM
Did you mean this...
...to this ?
Make all your layers visible again !
...to this ?
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 28 FRA FULL
OS 13 Ventura - MacBook Pro M2 max- 32Go RAM
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-07-23 04:34 AM
‎2019-07-23
04:34 AM
When you select an item in the schedule, and it's locked or hidden etc, then a panel will appear on the left at the bottom for information about the selected item (why it's not editable).
James Badcock
Graphisoft Senior Product Manager
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-07-23 10:32 AM
‎2019-07-23
10:32 AM
James wrote:Dear James,
Okay, some of my elements are locked, but how can I unlock them if I can't see which doors are problematic in a 3D window?
Kind regards,
Karol
OPENBIM does works!
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-07-23 10:58 AM
‎2019-07-23
10:58 AM
Karol wrote:Open a 3D view.
Turn all the layers on that have doors in them.
Then issue the 'Unlock All' command in the Edit menu or with the tool bar button if you have one.
This is assuming you have teamwork permission to unlock them (I don't use teamwork so not exactly sure what you have to do there).
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-07-23 11:05 AM
‎2019-07-23
11:05 AM
Karol wrote:Hi Karol.
Dear James,
Kind regards,
Karol
If the element is visible in the model, but locked, then the show on floor plan/3d buttons will still be active. Try going to floor plan, turning on all layers, going back to the Schedule (use the project map to navigate for this rather than views which store the layer combination) then show in floor plan that Wall that is locked. You can zoom to it, and it'll select (with light grey nodes).
(EDIT: Or as Barry said
James Badcock
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-07-23 11:25 AM
‎2019-07-23
11:25 AM
Hi Karol
Unlock all your layer
Or
Unlock all (Edition/Lock/unlock all)
Or
Add the unique ID to see which élément is locked
Or
Or
Christophe - FRANCE
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-07-25 09:36 AM
‎2019-07-25
09:36 AM
Thank you all for support, Unlocking all layers worked like a charm!
Regards,
Karol
Regards,
Karol
OPENBIM does works!
