Schedules and Formulas
I understand that from AC22 on you can use formulas. I can easily make schedules that add totals but would like to be able to subtract areas and produce percentages. Typically for project data. Below is a sample of what kind of schedule I would like to create:
I would like to create a schedule that:
Title: "Project Data"
Site Area (zone) sq. ft.
Building Area (zone) sq. ft.
Site Coverage (Building Area / Site Area as a %)
Open Area (Site Area - Building area) sq. ft., %
Calculates Gross Floor Area (zone) sq. ft., by storey, total
Net Floor Area (gross floor area minus exclusions) (zone) sq. ft., by storey, total
Floor Area Ratio (net floor area / site area) sq. ft.
Units By Type (based on zones), by storey, total
Density (units per acre)
same as above using m2 listed next to the sq. ft. numbers
Thomas Allan Palmer
Architect AIBC MRAIC
ArchiCAD 24 MacBook Pro
Mac OS Catalina 10.15.6
11 REPLIES 11
The AC22 default template file already has many examples of formulas on which you can base yourself
What's your question ?
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
Schedules themselves still do not have any calculations other than simple totals.
You can use Expressions (formulae) in Properties, and these properties can be associated to elements (including zones).
And you can schedule these properties.
However, the properties can only relate to one element.
By that I mean they can not see the values of other elements.
So you can not do calculations for site/building ratios that compare one zone to another - unless you manually input the site area into the building zone properties and then do a calculation.
The building zone has no idea what the site zone properties are.
I hope that makes a little sense.
I don't understand the question and now even less your answer Barry
Could you illustrate your words ?
Christophe - FRANCE
Let me try.
If you want to find the ratio of building zones to the overall site zone (area), you can not do this directly.
The building zones have no idea what the site zone area is nor do they know what the other building zone areas are.
Likewise the site zone does not know what the areas of the building zones are.
You can add a property to the building zones where you can 'manually' input the site zone area.
Then you can calculate the ratio and you will have the ratio of one building zone to the site area.
For multiple building zones you can total the ratio in the schedule.
However for every building zone you will have to manually adjust the site area - which hopefully will not actually change.
But my point is that it is not a fully automatic process.
The zones (nor their properties) do not actually 'talk' to each other.
You can do all sorts of clever calculations with properties, such as rounding the length of a timber beam, or calculating the number of bricks in a wall.
But these are all calculated on a single element and then simply totalled in the schedule.
Is that any clearer?
Back to Thomas' original question.
Yes you could calculate some of those things (with or without properties), but it won't be fully automatic.
Thanks for the feedback.
Looks like using excel is still the best option.
I'm attached some simple spread sheets that would be nice to produce inside ArchiCAD
Thomas Allan Palmer
The ratios can be done but will not be 'live'.
You will need to add a property to each zone (that can be automatic) that contains the value of the site area.
That value can be a default but can not be changed universally for all zones if needed - that must be done manually in each zone.
The SQM - SQF can be done with expressions in the properties.
Create a new property that converts the units you are working in to the other unit.
You can then schedule bot the default area (SQM) and also the other property area (SQF).
This will be live as the area is contained within the zone itself and it does not need to rely on any other zones.
These aren't examples of you specific requirements, but are examples of what can be done..
https://helpcenter.graphisoft.com/user-guide/76728/
Thanks Barry.
I'll give the m2 to sq. ft. a try.
Thomas Allan Palmer
From my curiosity, I have tried to test this solution by storing the sum of area in the property. You can calculate the ratio for on apt and then add a percentage. However, since it's the expression you cant sum it up in schedule... even if I left it as number value.... proc num column on attachment.
'proc num' column has totalled correctly.
