Teamwork between M1 macs and Intel?
Maxam
I vaguely remember maybe seeing something about Teamwork not being compatible between new M1 Macs and older intel chip Macs.  Can anyone confirm if we can mix and match client computers when using BIMcloud? Or does everyone working on the project need  to be on M1?
2 ACCEPTED SOLUTIONS
I cannot imagine that it would matter.  At present, the M1 Mac is running exactly the same code as the Intel Mac... emulated Intel via Rosetta 2.  BIMCloud should not be able to distinguish between. the two.
AC 28 USA and earlier   •   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Pieter
We are using Macs with the M1 and intel macs, on several teamwork projects at our office.
We have not experienced any problems with this.
4 REPLIES 4
Pieter
Jono
Is there a current update on this?
The download versions for 26 are:
4024 for Silicon and
3001 intel.
However on intel now my Update lists 4034 as current *note This is a macOS 13 Ventura compatibility update.
we work with a correspondent who has upgraded to silicon we are yet to. the issue is build numbers and Bimcloud teamwork file versions and specifically the file been authored on the later version been accessible to us on intel version.
latest available updatelatest available updateSilicon base numberSilicon base numberIntel base numberIntel base number
Architect - South Africa
macOS Big Sur
MacBook Pro (Retina, 15-inch, Mid 2014)
*Processor 2.5 GHz Quad-Core Intel Core 17
Memory 16 GB 1600 MHZ DDR3
Graphics NVIDIA GeForce GT 750M 2 GB
Jono
I think I have answered my own question doing some more searching.
see image.
macOS Big Sur
