2020-08-21 05:25 PM
Solved! Go to Solution.
2020-08-25 10:56 AM
Posednak wrote:it would be helpfull to know how the files are shared.
We work on shared HDD
2020-08-29 10:20 AM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-08-30 10:56 AM
mnguyen wrote:There is a setting in AutoCAD that enables xREF load with copy where AutoCAD essentially copies the xRefed file to a temporary folder in your hard drive, if this setting is not enabled the behaviour is exactly the same as that of Archicad
I believe Autodesk applications have a different way to bypass this. Unfortunately, you (or your colleagues) need to close the file before you can start attaching the DWG as XREF.
Best regards,
Minh
2023-04-08 10:28 AM
2023-04-08 10:35 AM
As discussed, it could be that someone else has the DWG open.
I have also found on a Windows system, just having a file selected in Widows Explorer with the 'preview' panel active, is enough for Archicad to think the file is in use.
2023-04-08 03:26 PM
Also even if you close the file in Autocad the file can still read as locked until you quit Autocad.
another Moderator
2023-04-08 08:30 PM
Thank you very muchh
2023-04-08 08:31 PM
Thank you very muchhh...
