If it is a parameter that you set in the window for this information, then in the schedule scheme settings you can click on the little arrow next to the 'Add Fields' button and choose 'Library Part Parameters'.
If it is the name of the object (window) that defines the type, then you need to add the 'library part name' to the fields.
