Window Schedule - Opening Type and Transom fields
Hi all,
Just wondering if there's a way to add fields for the opening type and/or whether the window has a transom to a window schedule. We'd like to sort windows by similar types (ie awning windows, sliding windows, etc) but I can't see any fields for this.
Thanks in advance
If it is a parameter that you set in the window for this information, then in the schedule scheme settings you can click on the little arrow next to the 'Add Fields' button and choose 'Library Part Parameters'.
If it is the name of the object (window) that defines the type, then you need to add the 'library part name' to the fields.
Library Part Parameters - that's exactly what I was looking for. Thanks Barry!
I'd search right through parameters and properties and right through IFC properties but for some reason skipped over Library part parameters
