cadimage wall builder (NZ)
I am trying to find out how to reslove the following question with walls- cadimage wall builderm part of the accessories tools.
When i add a wall builder (cladding) to a wall be it composite or fill pattern and I have an hidden wall underneath from my demolition walls layer, the wall builder breaks either side of the wall.
I have tried changing the different walls to different intersection group numbers and display order without success.
Thanks in advance
Probably your only option is to strighten up the mitres, and stretch the accessory across the gap joining it to the other side using the editing nodes in plan view.
Gerald Hoffman
Try trimming the demolition walls to the inside face of the exterior walls which have the cladding attached. If you can keep them from auto joining they will not be seen by the add-on.
Gerald
"The simplification of anything is always sensational" GKC
AC 25-4013 USA, CadImage Tools
2019 MacBook Pro 16" w/ AMD Radeon Pro 5600M GPU
OS X 11.6
2.4 Ghz 8 core i9, 64 GB RAM
27" LG 5K Monitor
Erika Epstein
Thanks in advance
Have you turned on all the layers to see if there is another object that might be causing this gap?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
