dwg import problem all lines the same weight
Hi, everyone. I use archicad for several years, bet this year is the first time i had to import and export to autocad dwg file and i confronted with dwg importing issue. When i import dwg, all lines are shown with autocads colors, but the lineweights are the same weight 0.18. Want to know if this problem could be solved somehow?
1 REPLY 1
You can try to set up a Pen-Color Conversion Table in the DXF/DWG Translation Setup Dialog. Then a given AutoCAD color will be converted to a given ArchiCAD Pen, I suppose.
