window in a door Schedule
Hi! how I can list a door in a window shedule and Type?
Thanks
1 REPLY 1
The same as with you question with skylights you need to add criteria to look for windows OR doors.
Then add the filed for TYPE and you should have what you are after.
The problem with adding doors and windows together in a schedule is that you may have parameters (fields) that are only applicable to doors or windows and not both.
i.e. door panel type or window glazing type.
So you will have blank spots in the schedule output.
