Archicad for Linux
I think the linux market share will grow in 2005.
I usually work with OpenOffice 1.9, Mozzila, Gaim, Skype, Oracle 10g, GIMP 2.1, Blender, Dia, ArcGIS 9.0 software that run on windows and linux,
I would like to work with a version of Archicad for linux,
Now we only have Building Information Modeling (BIM) software in linux:
- ARCAD 90, from www.arcad.de - only in german i think
- BricsCad, (brings DWG to the LINUX community) beta version, from www.bricscad.com
and a old 2D Software - Microstation 95 for Linux
Does anybody know if there will be a linux version of archicad in 2005?
thanks,
Bernardino
153 REPLIES 153
I cannot estimate the linux market for ArchiCAD, nor can I estimate the amount of work required for a port. I do expect that some, and hopefully much of the Mac OSX code could be used in a linux port. Reducing the dependence on Microsoft APIs, particularly in the installer would also help running ArchiCAD under WINE.
I support the machines for a small (~40 architects) office. Currently, ArchiCAD is in use on Macs running MacOS9, and AutoCad is in use on PCs running Windows 2000.
The Mac hardware is getting too expensive to justify further purchases. In addition, our tests of OSX show it is still too unreliable to be used seriously on our existing Macs, and it is *very* different to either OS9 or Windows, making it a difficult learning curve as well.
So we will only buy PCs in the future, and will replace the Macs with PCs over 2005. We will standardise on either AutoCad or ArchiCAD, depending on which we can run successfully on linux.
ArchiCAD on Windows works well, and we would be very happy to get it working under WINE. We have already run earlier versions of AutoCAD under WINE with encouraging results, though not yet anywhere near complete success.
We are prepared to run under Windows 2000 for another year yet, but our experiences with viruses, Windows' poor multi-tasking, limited security model, etc mean we *will* migrate to linux by the end of 2005.
Cheers!
Nik
Spoken like a true IT Manager, 40 Architects dont come cheap either
OSX wont run well on old hardware, but have you tried running XP on a 4yearold + machine!
May you be plauged with a thousand viri
TomWaltz
And when is the AutoCAD for Linux coming?
Tom Waltz
stefan
Nik777 wrote:
[...]Reducing the dependence on Microsoft APIs, particularly in the installer would also help running ArchiCAD under WINE.
ArchiCAD 9 installer is apparantly Java-based.
Nik777 wrote:
[...]We will standardise on either AutoCad or ArchiCAD, depending on which we can run successfully on linux.[...]we *will* migrate to linux by the end of 2005.Cheers!
Nik
Good luck then.
AutoCAD is more and more plunging into the MS platform, with more and more .NET tools.
ArchiCAD at least has cross-platform development, but no announcement of ever running on Linux.
I guess you should migrate to BricsCAD (based on IntelliCAD) running in Linux through Wine. And it will almost work like AutoCAD, with a different interface, but running the same commands and the DWG format. And it's a BIM modeller as well 😉
(But I should not say this in an ArchiCAD forum)
Archicad27/Revit2023/Rhino8/Unity/Solibri/Zoom
MBP2023:14"M2MAX/Sonoma+Win11
Archicad-user since 1998
my Archicad Book
Stephan,
you are such a partisan when it comes to software. javascript:emoticon(':D')
Very Happy
Think Like a Spec Writer
AC4.55 through 27 / USA AC27-4060 USA
Rhino 8 Mac
MacOS 14.2.1
I have to disagree here. I have been working with many clients using OSX for over two years and various Windows and Mac systems for many more. OSX is by far the most stable, productive, and easy to learn operating system I have seen. (Linux may be more stable, but it is still not as easy to deploy or as versatile as a mainstream desktop solution.)
OSX is much easier to learn than OS9 or Windows. I have watched new users on all these platforms over the years and OSX wins by far. I have seen dyed-in-the-wool Mac users resist and complain about the changes, but eventually they come around (haven't much choice really).
I have also seen veteran Windows users light up when they discover all the things they can easily do in OSX that they could never get to work (or didn't have time for) in Windows.
The hardware cost is a red herring. I am familiar with many of my clients' IT budgets, and the Windows shops consistently spend more on their computers. Just because you can (maybe) but a box on a desk for a couple hundred less doesn't mean that the system as a whole is cheaper. Studies have consistently shown that the TCO (total cost of ownership) is considerably less for Macs than PCs. This was true with OS9 and earlier, OSX is even better.
stefan
Let's not turn this into a Windows vs. Mac debate again...
my Archicad Book
stefan
My XP is running just fine at home on a P3 600 MHz from the beginning of 2000. It's not speedy, but very workable. It's not used for rendering though...
MacOSX is running (very slow) on my PC running WindowsXP at work with the help from PearPC. Not that I would run ArchiCAD on it (but I'm trying to learn cross-platform development so I might try it anyway).
Linux is installed on the same PC (in dual boot, so it can run at full Speed). I have not tried to boot ArchiCAD with WINE but I highly doubt that it'll work out-of-the-box...
my Archicad Book
The best solution to maintain a platform independant version is to use cross platform libraries in the development.
I would guess that a lot of the code is already platform independant as MAC and Windows is supported.
If Graphisoft could move the presentation layer also to a cross platform base they would be independant from the OS.
One solution to this is the eminent Qt library from Trolltech. It is an industry proven solution with a lot of success stories.
- Opera www.opera.com, is a Qt based product and opera is deliverd to BSD, Unix, Linux, Mac OSX, Windows 95-XP, Solais AIX.....
- the KDE desktop environment for Linux/BSD www.kde.org
- http://www.trolltech.com/success/index.html
regards
Birger Kollstrand
stefan
I can agree with this. I'm studying Qt right now, since I'm planning to move my MFC-based research-application to Linux & Mac OSX and Qt came as the best solution to me.
GS is allready developing their own user-interface elements and resource handling (well, at least for the API. Can't say if that is also true for the regular code), it might not even be necessary to do everything in such a toolkit.
But it would be a tremendous effort and I'm not sure if it'll translate well into Linux too.
I guess GS is using CodeWarrior on Mac and Visual C++ on PC (that's what you need for API-development) so they also have to port their code to the gcc-compiler and that might cause a few problems.
Well, the day there is commercial demand to have ArchiCAD running on Linux, they might do this, but I don't think this demand is there today.
my Archicad Book
