2023-01-07 01:03 PM - last edited on 2023-05-11 11:10 AM by Noemi Balogh
I am a beginner with connecting Rhino Grasshopper and Archicad... already running into teething problem.
I am using Rhino 7 and Archicad 25.
Got the add-on downloaded and installed in Archicad. The Archicad tab is also showing when I start the Grasshopper.
In Archicad, The 'Grasshopper Connection' is not showing up in the 'File > Interoperability > Grasshopper Connection' as mentioned in the user guide. But it is showing up in the 'Window > Palettes'. Upon starting, the 'Start Connection' is functioning.
In Grasshopper, when I open the 'Connect Document to Archicad', the file is showing up in the selection menu and I can select it. However, the 'Connect' button at is greyed out and doesn't let me press it.
Anyone knows why? Hope it's a easy fix... looking forward to trying the feature out.
Thanks,
Gloria
