The door panel surface is height "0". Your handle must grow positively above this.
Select your plate and look at the Info Box. The value for the bottom surface should be 0" and the top should be 1/16".
Hope that helps.
One of the forum moderators
AC 27 USA and earlier • macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
