2005-09-29 08:28 PM - last edited on 2023-05-24 12:48 PM by Rubia Torres
2005-09-30 10:23 AM
DHURD wrote:normally the parameters you have inserted before saving the object will be set when you place the object
Where can I set the default parameters so that every time I insert objects they all come in w/ the same section fill, 2d pen.....?....
2005-09-30 02:54 PM
Thanks.
2005-09-30 04:11 PM
David wrote:For objects that require a lot of parameter setting, it typically makes sense to insert them into a 'toolkit module file' (say, a 'kitchen toolkit' pln with all your kitchen cabinets and equipment, a bathroom toolkit, a 2d drafting toolkit) some of which may be linked to your templates and some of which you may want to bring in only when you are working on a project type that will require their stuff ('trees and landscaping', 'cars', 'office equipment', 'residential doors and windows', whatever), and tweak them over there, or copypaste them into that file from some project where you've already tweaked them. On your new projects you then bring in the module and option-click+insert, or have them open on a second/third/fourth ArchiCAD session and copy-paste.
go to File>GDL Objects>Open Object...
2005-09-30 05:48 PM
DHURD wrote:something I did for my company is place a module that is off to the side of the project, and kept on its own story. That story can be turned on as a ghost story.
Related question for Window builder ad on. Where can I set the default pen color of the marker text for instance.
I do use a company template file, not the Archicad defaults.
2005-09-30 05:50 PM
2006-02-17 04:51 PM
