2019-02-26 02:45 AM
Solved! Go to Solution.
2019-02-27 01:47 AM
2019-02-26 03:10 AM
If GLOB_VIEW_TYPE = 2 THEN !Plan view CUTPLANE 0, cutplane_height endIf
If GLOB_VIEW_TYPE = 2 THEN !Plan view Rotx 90 endIf
generate an elevation view on plane of the object using project2 (along side the plan cut)
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win10 | R5 2600 | 16GB | GTX1660 |
2019-02-26 03:24 AM
2019-02-26 03:35 AM
If GLOB_VIEW_TYPE = 2 THEN !Plan view CUTPLANE 0, cutplane_height endIf ... 3D model script ... If GLOB_VIEW_TYPE = 2 THEN !Plan view CUTEND endIf
2019-02-26 03:36 AM
PROJECT2{4} 3, -90, !projection_code, angle, 0, 1+2, !useTransparency, statusParts, 1, !numCutplanes, gs_fw_lower + gs_int_fw + 2*gs_louvre_width, !cutplaneHeight1, ..., cutplaneHeightn, 3+32, 1+2+4+8+64, !method1, parts1, gs_fill_type, !cutFillIndex1, gs_fill_pen, gs_back_pen, !cutFillFgPen1, cutFillBgPen1, 0, 0, 0, !cutFillOrigoX1, cutFillOrigoY1, cutFillDirection1, gs_cut_pen, 1, !cutLinePen1, cutLineType1, 65, !projectedFillIndex1, 19, 19, !projectedFillFgPen1, projectedFillBgPen1, 0, 0, 0, !projectedFillOrigoX1, projectedFillOrigoY1, projectedFillDirection1, gs_pen_2D, 1, !projectedLinePen1, projectedLineType1 4+64, 1+2, !method1, parts1, gs_fill_type, !cutFillIndex1, gs_fill_pen, gs_back_pen, !cutFillFgPen1, cutFillBgPen1, 0, 0, 0, !cutFillOrigoX1, cutFillOrigoY1, cutFillDirection1, gs_cut_pen, 4, !cutLinePen1, cutLineType1, 65, !projectedFillIndex1, 19, 19, !projectedFillFgPen1, projectedFillBgPen1, 0, 0, 0, !projectedFillOrigoX1, projectedFillOrigoY1, projectedFillDirection1, gs_pen_2D, 4 !projectedLinePen1, projectedLineType1 add2 0, 0.05 PROJECT2 4, -90, 3
2019-02-26 04:16 AM
project2{4} 3, 270, 0, 0, 1, __h, 3, 1+2+8, 1, 1, 1, 0.0, 0.0, 0.0, 1, 1, 1, 1, 1, 0.0, 0.0, 0.0, 1, 1, 3, 1+2+4+8, 1, 1, 1, 0.0, 0.0, 0.0, 1, 1, 1, 1, 1, 0.0, 0.0, 0.0, 1, 1
project2{4} 3, 270, 0, 0, 1, __h, 3+64, 1+2+8+64, 1, 1, 1, 0.0, 0.0, 0.0, 1, 1, 1, 1, 1, 0.0, 0.0, 0.0, 1, 1, 3+64, 1+2+4+8, 1, 1, 1, 0.0, 0.0, 0.0, 1, 1, 1, 1, 1, 0.0, 0.0, 0.0, 1, 1
2019-02-26 04:55 AM
2019-02-26 05:25 AM
2019-02-26 05:34 AM
2019-02-26 08:15 AM
