2019-04-23 11:23 AM - last edited on 2022-05-05 03:51 PM by Gordana Radonic
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
2019-06-13 12:59 PM
2019-06-14 03:35 AM
!!! Pull Complex Profile !!! COMPTYPE_CORE = 0 COMPTYPE_FINISH = 1 COMPTYPE_OTHER = 2 if GLOB_SCRIPT_TYPE = 2 or GLOB_SCRIPT_TYPE = 3 or GLOB_SCRIPT_TYPE = 5 then _nComponents = 0 dim _componentTypes[] n = REQUEST{2} ("Profile_components", myProfileIdx, _nComponents, _componentTypes) n2 = REQUEST ("Profile_default_boundingbox", myProfileIdx, _xMin, _yMin, _xMax, _yMax) n3 = REQUEST{4} ("Profile_component_info", myProfileIdx, _nComponents, "gs_profile_surface", bMat_profile) If rafPro = "Complex" then ProWidth = abs(_xMax - _xMin) ProHeight = abs(_yMax - _yMin) SquareV2 = ProHeight / ( cos(phi) ) endIf if n then dim _bShowPart[] _needRequestDetails = 0 for _i = 1 to _nComponents _bShowPart[_i] = 1 if GLOB_STRUCTURE_DISPLAY = 1 AND _componentTypes[_i] <> COMPTYPE_CORE then _bShowPart[_i] = 0 ! GLOB_STRUCTURE_DISPLAY: 0 – entire structure, 1 – core only, 2 – without finishes if GLOB_STRUCTURE_DISPLAY = 2 AND _componentTypes[_i] = COMPTYPE_FINISH then _bShowPart[_i] = 0 if _bShowPart[_i] then _needRequestDetails = 1 next _i if _needRequestDetails then dim _profileGeometryRawData[] n = REQUEST ("Profile_default_geometry", myProfileIdx, _profileGeometryRawData) ! n1, n2, ..., nn, x11, y11,s11 dim _contStartPoints[] dim _contEndPoints[] _contStartPoints[1] = _nComponents + 1 for _i = 2 to _nComponents _contStartPoints[_i] = _contStartPoints[_i - 1] + _profileGeometryRawData[_i - 1] * 5 _contEndPoints[_i-1] = _contStartPoints[_i] - 1 next _i _contEndPoints[_nComponents] = vardim1(_profileGeometryRawData) endif endif endif !!! Pull Complex Profile 2 !!! if GLOB_SCRIPT_TYPE = 2 or GLOB_SCRIPT_TYPE = 3 or GLOB_SCRIPT_TYPE = 5 then _nComponents2 = 0 dim _componentTypes2[] n = REQUEST{2} ("Profile_components", myProfileIdx2, _nComponents2, _componentTypes2) n2 = REQUEST ("Profile_default_boundingbox", myProfileIdx2, _xMin2, _yMin2, _xMax2, _yMax2) if n then dim _bShowPart2[] _needRequestDetails = 0 for _i2 = 1 to _nComponents2 _bShowPart2[_i2] = 1 if GLOB_STRUCTURE_DISPLAY = 1 AND _componentTypes2[_i2] <> COMPTYPE_CORE then _bShowPart2[_i2] = 0 ! GLOB_STRUCTURE_DISPLAY: 0 – entire structure, 1 – core only, 2 – without finishes if GLOB_STRUCTURE_DISPLAY = 2 AND _componentTypes2[_i2] = COMPTYPE_FINISH then _bShowPart2[_i2] = 0 if _bShowPart2[_i2] then _needRequestDetails = 1 next _i2 if _needRequestDetails then dim _profileGeometryRawData2[] n = REQUEST ("Profile_default_geometry", myProfileIdx2, _profileGeometryRawData2) ! n1, n2, ..., nn, x11, y11,s11 dim _contStartPoints2[] dim _contEndPoints2[] _contStartPoints2[1] = _nComponents2 + 1 for _i2 = 2 to _nComponents2 _contStartPoints2[_i2] = _contStartPoints2[_i2 - 1] + _profileGeometryRawData2[_i2 - 1] * 5 _contEndPoints2[_i2-1] = _contStartPoints2[_i2] - 1 next _i2 _contEndPoints2[_nComponents2] = vardim1(_profileGeometryRawData2) endif endif endif
2019-06-15 06:57 PM
2019-06-17 03:24 AM
2019-06-17 02:53 PM
2019-06-17 04:53 PM
2019-06-18 03:10 AM
2019-06-20 06:23 AM
2019-06-20 06:40 AM
