How I can edit one array element in UI_INFIELD?
I have the parameter as array of the 10 text strings - MyStrArray
I need to edit any of elements of the array. For example - first element (MyStrArray[1]).
I try to write in user interface secrion:
UI_INFIELD MyStrArray[1], ...
Not work
UI_INFIELD "MyStrArray[1]", ...
System says that variable not exist.
2 REPLIES 2
You can use ui_infield{3}
ui_infield{3} MyStrArray[1], 62,20, 342, 20
Thank you!)
