Problems importing a texture into Archicad 24
Hey, I am having a problem importing a file I downloaded from BIMcomponent to my Archicad Material Surfaces library.
It is a .mod file of a stone cladding and it doesn't want to import. How do I add it?
A MOD file is a Module file.
So you would use the File\External Content\Place Hotlink menu command to place it in your project.
It really helped, thank you very much
