No sorry my solution doesn't work in 19 - not the initial release anyway.
It is supposed to work when the next hotfix is released to give us time to change our scripts before it stops working again in 20.
But just what can we change our scripts to.
I use GLOB_CONTEXT quite a bit.
This is a classic example of how.
Or in a schedule I use it to control the 2D symbol of an object so it is not rotated/reversed just because the object was placed that way.
Can someone from GS please explain if we can no longer use GLOB_CONTEXT how can we set a parameter based on the context of what is happening to the object at that time?
i.e. how do we get around this particular problem of resetting a Boolean parameter when we are not viewing the object settings dialogue.
This would be greatly appreciated.
I agree with Kistian in that we want objects to change dependent on the views - teamwork or no teamwork.
What is the solution?
