Any favourites that you create can be exported from that file and imported into any other file.
As Eduardo suggested, create a template file that you start every new job from.
Keep this template up to date with new favourites, attributes (lines, pens, layers, composites, etc.), renovation filters, graphic overrides, layouts, etc.
Basically set up as much as you can in the templates so you don't have to keep doing it for every job.
You don't need to save it as a TPL (template) file, it can just be a PLN that you have saved somewhere.
When working on a job and you decide you need something new (favourite, layer, graphic override, etc.) you then export this and import it into the template so it is there for the next job.
Or some people will work on a job making changes they need, then use that job as the latest template - just strip away the 3D model and annotation that you don't need.
