2021-09-21
09:29 AM
2022-09-28
09:57 AM
Oleksandra Vakariuk
For some reason the "WALHOLE" comand is not working to make custom wall openings. Where can one chose, eg. slab, to be editable or not?
Solved! Go to Solution.
2021-09-21 02:39 PM
Can you share the part of your code where you are using "WALLHOLE" so the issue can be evaluated?
2021-09-21 06:05 PM
If you are assigning a slab in the floor plan as "WALHOLE" then save it out as a window or door, your spelling is the issue.
AC22-23 AUS 7000
Self-taught, bend it till it breaks.
Win10 | R5 2600 | 16GB | GTX1660
2021-09-21 07:38 PM
Yes, the ID of the Slab must be "WALLHOLE" with 2 "L" characters, not with 1 "L".
2021-09-22 09:30 AM
Thanks, Laszlo
My bad. It used to be with one L long time ago. I guess I am getting old.
2021-09-22 06:20 PM
+1 IDE update w/ autofill.
AC22-23 AUS 7000
