‎2021-09-21 06:29 PM - last edited on ‎2023-05-24 12:30 PM by Rubia Torres
For some reason the "WALHOLE" comand is not working to make custom wall openings. Where can one chose, eg. slab, to be editable or not?
Solved! Go to Solution.
‎2021-09-22 03:05 AM
If you are assigning a slab in the floor plan as "WALHOLE" then save it out as a window or door, your spelling is the issue.
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
‎2021-09-22 04:38 AM
Yes, the ID of the Slab must be "WALLHOLE" with 2 "L" characters, not with 1 "L".
‎2021-09-21 11:39 PM
Can you share the part of your code where you are using "WALLHOLE" so the issue can be evaluated?
‎2021-09-22 06:30 PM
Thanks, Laszlo
My bad. It used to be with one L long time ago. I guess I am getting old.
‎2021-09-23 03:20 AM
+1 IDE update w/ autofill.
