The outfield and the tooltip can be different.
But if you are using a variable instead of a quoted string, you will just need to create a second variable (can be hidden from users) that has the &&&, that will change as you change the original variable.
So as the user changes the original variable, the second will automatically change as well and will be used for the tooltip.
