GDL
CPRISM_ question
Patrick M
Mentor
I feel like a total idiot for asking, but I'm trying to script a shape that is basically a rectangle with rounded ends. Using the CPRISM_ (or PRISM_) command, I have the following:
CPRISM_ materialAttribute_1, materialAttribute_1, materialAttribute_1,
7,.393701",
0,0,15,
1.73228",0,15,
1.73228",.433071",900,
1.73228",.866142",3015,
0,.866142",15,
0,.433071",900,
0,0,3015
what I am getting is a convex end on one side and a concave end on the other. It's showing as: (_(   instead of  (_)
I'm sure it has something to do with the second 900 status code, but can't figure out what that needs to be to be orientated correctly.
I am also getting a warning:"Undefined arc at line 50 of the 3d script"
Line 50 is the CPRISM_ materialAttri... line; what needs to be defined there to eliminate this warning?
Again, sorry for the basic stupid scripting question. Hoping someone can see this and correct my (probably obvious) error soon. THANKS!
julienK
looks like a rounding error, since you doing a 180deg arc  gdl gets confused as to whicj direction to go. you have 2 options:
1: you add a slight gap on the  end of the second arc to be less that 180deg
7,.393701,
0,0,15,
1.73228,0,15,
1.73228,.433071,900,
1.73228,.866142,3015,
0,.866142,15,
0,.433071,900,
-.0001,0,3015
2:  (Better solution) you use  the tangential arc by radius and angle which will ensure that the arc is always in the right direction
6,.393701,
0,0,15,
1.73228,0,15,
0,.866142,15,
.433071,180,2015
you also have some quotes at the end of some coordinates that you should remove (probably the reason for the undefined arc error)
also,  not necessary but you should use variables instead of hard coded  values when doing gdl.  Allows to adjust the object later and make it reusable.
4 REPLIES 4
julienK
7,.393701,
0,0,15,
1.73228,0,15,
0,.866142,15,
0,.433071,900,
-.0001,0,3015
6,.393701,
0,0,15,
1.73228,0,15,
0,.866142,15,
.433071,180,2015
That got me what I needed! thanks!
the hard coded parameters are only because this is a manufacturers object. Typically I'd allow for it to be adjustable... well, technically, I would typically just model it with a morph and save as object for somethign stupid simple like this...
The double quotes are likely because those values are in inches (imperial), vs default/internal meters (no quotes) since 4dProof is a USA user.  The GDL interpreter does convert inch quantities to the corresponding metric value within scripts.
AC 28 USA and earlier   •   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
I didn"t know that.  Explains why i got weird results when trying to fix it.
