2020-08-30 09:12 AM - last edited on 2022-09-26 10:45 PM by Daniel Kassai
2020-09-04 04:53 PM
2020-09-04 06:55 PM
Mesh type needs to be solid. Using "with skirt" or "surface only" doesn't give the desired results.I will put a note for this in the instructions.
2020-09-05 08:21 AM
Braza wrote:I can't think of a use for it. Yet.
Also I don't see any need to override the Side/Bottom surface of the original Mesh as they usually are related to the BMSurface. Do you think it is needed?
2020-09-05 06:41 PM
vistasp wrote:Thanks for the feedback vistasp.
I can't think of a use for it. Yet.😉
You never know, though, what someone might use the object for, and the functionality is already built-in, so all good.
2020-09-06 06:48 AM
2020-09-06 08:11 AM
2020-09-06 08:37 PM
2020-09-06 09:45 PM
2020-09-07 12:08 PM
2020-09-07 12:31 PM
