GDL
Is there a tool / object for making a mesh with a specified thickness?
gedzior84
Hello.
As in the topic, I wanted to ask you guys if there exists any tool that would allow me to create a mesh with a specified thickness, or layers?
For example, I have a terrain to model, but the ground has layers: 3cm of grass, 10cm of ground and some other layers. The terrain is not flat - it has some holes and bumps. Is it possible to create this with one tool/object, not using layered slabs, roofs and shell?
52 REPLIES 52
Ok. I put the object to some stress and a couple of bugs came up.
Here is the updated version.
Also, if anybody wants to make any translation of this object, I would recommend to wait a little while before it is stable enough. Until then, I would like you to put some stress on it to reveal any bug.
A_ Smith
Braza wrote:
Try this object I've recently created.
It can add 6 skins from a Mesh saved as an object. If you need more tell me.
The skins are not really composites, as they are just offset of the original mesh object. But the result is pretty acceptable IMO.
I have troubles - can't add this object to the library (AC22). Is it possible to use it in previous versions? I assume it was created in AC24
AC 22, 24 | Win 10
Sorry A. Smith. I can't manage to do this right now. Only AC24 here. Perhaps someone else could help.
A couple of squished bugs and some interface optimization.
Here is a ramp created with this object.
Nice. Now we can start thinking about all its possible applications. I like it.
vistasp
Nice!
See, you needed the surface override for the mesh bottom.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC 9-27 INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
Is it stable enough to upload it to BIMComponents?
Another ramp.
Yves
Hello Braza,
Thank you very much for this beautiful object
Is it possible to add different cut pen for each of the skins?
Given that we place one or more hot points on the mesh before saving it as an object, we could delete hotspot 0,0,0 in 3D or put an option not to display it.
On the French forum Archi-CADlink we agree to translate the object into French with your agreement of course
For those who would like to have hotspots at the level of the skirt they could place with gravity one or more "virtual" object with just a hotspot2 0,0 and a hotspot 0,0,0 and save it with the mesh
Have a good day
Yves
Yves Houssier
Belgium
Archicad 19 -> 24
iMac - Mac Os 10,13
Yves
For A. Smith. and other users,
Here is the object AC 21
Yves Houssier
Belgium
Archicad 19 -> 24
iMac - Mac Os 10,13
