‎2022-10-20
06:16 PM
‎2023-05-25
08:22 AM
Noemi Balogh
Hello everybody,
I need some help if someone already tried to translate object from froeign language ?
We are using German library specially for doors and windows but it is so diffucult to parameter the objects in german .
Thanks
‎2022-10-20 06:49 PM
you have to open objects and translate their " parameter names " manually
‎2022-10-20 09:17 PM
some parameters it is done but the values not all the time editable
‎2022-10-21 05:41 AM
Parameters that are populated by Macros? So you would need to go into each macro and change the parameter there, which can go very deep... macro into macro into macro...
‎2022-10-21 08:35 AM
I am not sure it is macro or not.
But the problem specially with doors and windows (wich are better drawing, have better parameters in the German Library).
‎2022-10-21 01:59 PM
Short answer? Good luck!
Long answer?
Well, you'll need to open the object, go into the UI, and basically change all strings inside " ` " you can find. And then go into every macro and repeat... And it's macros all the way down!
The windows and doors are horrible. So back to the short answer: Good luck!
‎2022-10-21 02:12 PM
yeah better learn some german words
‎2022-10-25 10:19 AM - edited ‎2022-10-25 10:20 AM
In situations like this, I would recommend using LP_XMLconverter to convert the library into hsf format, and open the folder in VSCode (good idea to use our free GDL for VSCode extension 😉 ). With regular expressions in find&replace fields, you can make the process faster and then convert the files back to .gsm format.
This is the least technical solution I can think of, and still better than doing it inside Archicad, but yes, that is an option as well. 🙂
