GDL
Retrieve an array from the model view options
Hi!
I want to create an object that show the id of the object in plan.
But if the identifier of this object is present in the MVO list, I want it to display the text chosen by the user in the model view options (an abbreviation in my case)
I am not really experienced in GDL, so I don't know how to retrive an array from an other script.
!!!!!!!!!!!!!!SCRIPT PRINCIPAL
DIM valueT [][]
succes = LIBRARYGLOBAL ("OVM_Remplacement", "arrayValeurs" , req_arrayValeurs)
!!!! THIS PART DOESN'T WORK AT THE MOMENT
!for i = 1 to 3
!valueT[i][1]=req_arrayValeurs[i][1]
!valueT[i][2]=req_arrayValeurs[i][2]
!next i
Request ("ID_of_Main","",test)
compteur=test
!for i = 1 to 3
!IF test = valueT[i][1] THEN
!compteur=valueT[i][2]
!ENDIF
Archicad 27 - GDL - PYTHON
kuvbur
LIBRARYGLOBAL work only with 1d array
Structural engineer, developer of free addon for sync GDL param and properties
kuvbur
It worked well after making two 1d arrays. Thank you a lot!
Technically, returned arrays (libraryglobal, request, returned_parameters, ....) can be used as two-dimensional if declared with a fixed size in the receiving script. There are not many use cases when you know the size in advance.
Péter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
