GDL
index value greater than array dimension
LeeJaeYoung
dim  WallskinThk[4]
WALL_SKINS_NUMBER = 4
i use WallskinThk[4]
Sometimes the error message doesn't come out, then it comes up again.
Saving is possible, but it doesn't feel good.
AC27 on window 11
Assuming you always want the last skin,
WallSkinThk[WALL_SKINS_NUMBER]
Seeing the actual code would make it much easier to help.
5 REPLIES 5
The array is defined by the number of skins in the wall. So if at any time it's related to a wall with less than 4 skins you will get this error
So how should I set it up?
AC27 on window 11
thank you so much
AC27 on window 11
if WALL_SKINS_PARAMS[idx][SKIN_CORE_STATUS] > EPS then
            cumCoPen = WALL_SKINS_PARAMS[idx][SKIN_CONT_PEN]
endif
PEN cumCoPen
Error occurs here too.
What should I do?
AC27 on window 11
