Dimensioning on a section
Dontknow
Hi all, is it possible to make a dimensioning on a section including a dash-dot dimension line like the example below?
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
Dontknow
Meanwhile I found out its the witness line set to 'Dynamic Height'.
Looks like you can't set the line type.
ArchiCAD 25.
Dimensions have no control over the line type.
