Read more
Pen problem
Aula
Hello all,
I'm using Archicad 22 and have an odd problem.
One of my drawings is has peppermint green lines and hot pink fills, even though when I select the items, it claims they are pen 1 (black; which they should be). So if I select a green line and CTRL+T, it will state it's pen 1, although it is clearly not. If I go to any of my other drawings - same project, but on other sheets - the pens are fine (pen 1 for lines, fills varying shades of grey): basically, the visuals are the same as the parameters that show up when I CTRL+T
I have no idea what to do, so any help is most appreciated!
Thanks,
Aula
Guru
Check your Graphic Overrides  and Renovation Filters?
Guru
Thanks for the suggestion - my Graphic Overrides was configured incorrectly! THANK YOU!
