Document & Visualize forum
Why are these unique ID objects appearing twice in a schedule?
Kelly at Kanvi Homes
We have an issue with correct surface area in one of our schedules. There are 2 walls with stone in this project but they are each appearing in the schedule twice. Does anyone know why that would happen? I've attached a pic of the scheme settings and of the schedule which clearly shows the unique ID of both objects appearing twice. Thanks in advance,
Kanvi Homes is running AC24
6 REPLIES 6
brakpanpolisie
I had a similar issue only with roofs over here : https://community.graphisoft.com/t5/Document-Visualize-forum/Excel-Import-Element-is-duplicated-in-S...
For interest sake what kind of wall is it? Composite, complex profile etc?
Andre Steynberg
Win 10 64-bit
AC25
It's a composite wall, but with only one building material in it.
Miha Nahtigal
Your schedule should be of "Elements" type, not of "Surfaces"
I created a new elements schedule and it appears to be working correctly now. That still doesn't explain why the same unique ID object appears twice in one schedule.
I guess because the Wall has two sides and both sides are considered as individual surfaces in the Surface Schedule.
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
Also, I made a copy of the AC file and now the original surface schedule does not have duplicate items in it. Seems to be a bug in the original AC file???
