Read more
AC 21 Pen weight issue
Hi all,
Sorry for starting my membership here with a new topic, but I didn't find any similar questions or a solution for my problem.
Basically, I have a line drawing and I wanted to change the line weight from 0.13 to 0.05
Unfortunately, these lines on the layout sheet or in the published pdf appear as a light grey line. (every line below 0.13)
I used true line weight while I was editing these lines.
Is there any idea what I do wrong or any tip to solve it?
thank you,
Marton
Takis
Check that the drawing on Layout has the same Pen Set as the one you have on the view.
Takis.
Thank you Takis, it worked !
