Archicad 22 - text isn't publishing in the pdf
ngoldie
I am trying to publish floor plans and elevations, the text is showing up in layout but when it publishes it doesn't show up?
Thanks
Naomi
Archicad 20
MacBook Pro - laptop
mikas
If it's Helvetica you could try to change it to arial for example.
That has solved this kind of a problem in AC21 sometimes. Or start over if it doesn't help, it might go away with boot. It's an annoying problem not present all the time.
AC27, Rhino7/8+Grasshopper, TwinMotionMac Pro 6,1 E5-1650v2-3,5GHz/128GB/eGPU:6800XT/11.6.5 • HP Z4/Xeon W-2195/256GB/RTX4080FE 16GB/W11ProWS
ngoldie
Thanks I'll try changing the font.
I already rebooted once, I'll try that again too.
Thanks again!
Archicad 20
Same issue occurs in 26 with dimensions.  Dimensions using Helvetica font will not print.  Change to Arial and then it prints fine.
Andrew Obermeyer | Architect
OBERMEYER Architecture
www.obermeyer.la
AC 26 Mac M1
