2022-11-28
03:05 PM
2023-05-17
12:34 AM
Gordana Radonic
I have experienced following behaviour with Archicad 26 Apple Silicon Version
Solved! Go to Solution.
2022-12-12 08:53 AM
Hi rikhav,
Based on information I received from GS HQ, they are handling Apple silicon-related bugs with high priority. To expedite the process, please contact your local reseller with this issue with all needed info (and files, if relevant) so they can evaluate it and process it and then forward it to GS HQ if needed.
2023-01-17 05:51 PM
There seems to be multiple threads on AC26 ARM bugs. Could we get those combined into one?
I'll add one:
When trying to open another AC file using either "Edit Module in Separate ArchiCAD" or "Open External Source View", there is a good chance (more than 75% of the time) that the new instance of AC will not find the license. It will return the "ArchiCAD License no found" dialog box.
If one returns to the original instance and tries again, AC fails to launch a new instance. One has to quit AC in order to restore the functionality of those commands.
One a project with multiple modules or multiple files linked together, this is a significant interruption to the workflow.
2023-02-01 07:24 PM
Adding to this - similar issue
When launching a new instance of AC from an already open instance, we receive the "ArchiCAD license not found" error.
Then, when we try again, AC fails to open/launch a new instance. We have to close the active project and then open the file within the same instance. This is very frustrating.
AC26 ARM is not functioning as designed when it comes to opening new instances of ArchiCAD.
2023-02-14 01:44 AM
and more bugs,
1. renovation pallet is not visible when the app is first opened. the reno pallet is checked, but requires unchecking then rechecking to show pallet.
2. when using dual monitors, and working on the second monitor window, selecting tools in the first widow will deselect when returning to the second window to use the tool.
3. text tool and label tools will at random time deselect after one use
4. changing views by clicking the view in the view map requires multiple clicks
5. zoom stops working randomly with magic trackpad and requires cycling the track pad power.
2023-02-16 10:55 PM - edited 2023-02-16 11:03 PM
and a few more
6. when grid snap is turned on, you can't grab the guide lines to move them
7. i know trace reference slows things down but i have a brand new file with three surface morphs and with a PDF trace ref i see a delay when selecting a morph from click to highlighting of up to 2 sec. on that note, this is a brand new Apple silicon studio, surely the trace ref should't affect the speed, with only a few polygons. i can't even imagine what it must be like with a large project.
8. there is a pause when panning with inertia on a mac turned on. swiping with the magic track pad the view moves, pauses, then continues the pan with inertia. very often though, the inertia doesn't work. swipe and it only moves as far as your fingers are on the TP. see movie
2023-02-16 11:23 PM
i think i have just decided to keep my SSA for one more year in the perhaps naive hope that the bugs will get worked out and AC27 will be optimized better for apple silicon to take advantage of the potential of these chips. i doubt it. i just can't justify paying to be frustrated all the time.
2023-02-17 12:46 PM
Especially no. 6 is so infuriating!
2023-03-15 09:06 AM
this one is annoying.
when opening AC26 apple silicon there are no palettes at all.
but, if a select one object and tenderize it, then ,after closing the window, the palettes are there!
2023-04-01 01:03 AM
guess you can't have aprons on corner windows. heck, why would we want them to match the other windows anyway? unless of course, there's some setting i should adjust that only applies to corner windows, that isn't in the corner window settings.
