Can I apply a Schedule format style to other?
ZuMedeiros
I created the perfect schedule using the format options. How can I apply the same options to other schedules?
Thanks
Miha_M
I usually clone a "good" schedule and change the element selection criteria settings.
Right click the good schedule and select "New Schedule...". In the new opened Scheme Settings / New Schedule Scheme window select Duplicate and give the Scheme a new name. Now go and change the Scheme Settings for element selection criteria.
I don't know of any way the options could be transferred from one to another existing schedule.
| Archicad 4.55 - 27
runxel
Legend
Sadly there is no easy way, but one that is not entirely obvious:
Export both schedules as XML (from the schedules settings dialog) and overwrite the styling part taking the one from the correctly styled schedule.
Sounds scarier than it is. Good luck!
