Can't build wall
designerasya
need tip 🙏
why i can't build new wall like in example in video ? 😞
what's wrong with my file or actions ?
6 REPLIES 6
mthd
Ace
Hi designerasya, I am not sure what you are specifically asking for but you can search “drawing walls in Archicad” online for more video tips like these below. Have fun.
https://youtu.be/Sg1VWBNv7Xw
https://youtu.be/6ltFUCBWD0c
AC8.1 - AC27 ARM AUS + CI Tools
24C GPU 7.8TF 32GB RAM OS Ventura
Guru
Maybe something to do with your Draw Order given that your slab / floor has a Coverfill on it.
Ling.
If you look at your image, a wall is being modelled there.
As Ling has suggested it might be hidden by the floor slab fill or some other fill.
mthd
Ace
According to the experienced users above, they are saying it might be a display order issue.
please see this link for how to sort the display order out. Cheers !
https://help.Graphisoft.com/AC/25/INT/_AC25_Help/030_Interaction/030_Interaction-106.htm
There is a Tip you can use in such cases when it seems an element was not created by your last step.
The Tip is simply to Undo once and Redo once (CTRL+Z, then CTRL+SHIFT+Z).
The Undo command will undo your last step (the element creation step). Then, the Redo command will redo the element creation step AND show the created element as selected. That way you will see the selection hotspots of the element even when the element is covered by a Cover Fill of another element and therefore not visible or hardly visible (so you will at least see it is there), and the Info Box will show its settings.
Since no one else has mentioned it, here's another possible explanation(/solution):-
The wall is there. However it's hidden  by a different element or object in a hidden layer that has higher priority or same layer number, like a massing slab or a Boolean (SEO) object.
If the wall was there and hidden by the floor slab fill, the cursor would still detect its edges when you hover over where it's supposed to be (by turning into the 'edge' Mercedes cursor from the magnet cursor symbol for surfaces and fills).  This is the quickest way to tell if that's that's the case.
Alternatively you can check if the wall is there but that section of it is eliminated (by layer order number), by seeing you can select the nodes where it connects with the other two walls. It will show a wall selected but missing that middle section (as opposed to the previous case where it highlights the entire wall with the hidden section as slightly faded out).
The easiest or quickest way to find out if this is the case is to isolate that area in 3D with a marquee tool, turn on all layers, and see if another object shows up where you expect to see the wall. And if that's the case and it's something you don't want to delete, then change its layer number to something different from the one that the layer containing your walls is using and that should clear up the problem.
This happens to me all the time when I forget that in an earlier version of a file I had conceptual massing slabs that I forgot to delete or have an appropriate layer number for and then when I start building walls in place, they disappear in certain views where the layer numbers are all coincident.
