Read more
Can't change steps configuration or materials
JohnJay
I've tried restarting AC but nothing I do seems to help.
No material changes or even steps type changes will change the look of the steps.
I've tried overriding materials and so on.
Tried creating new steps but structure and materials stay the same
(dimensions are ok though)
Any ideas pls?
edit: added image
Is there a way to reset the tool?
AC27 | i7990x | RTX4070 | W10
David Maudlin
JohnJay:
Look at Model View Options (MVO) > Stair Options > Stair 3D and Section/Elevation > and set to Full.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David Maudlin
JohnJay:
JohnJay
Thank you - that was it
I probably need a break...
Will add a sig before next post.
