2022-04-25 08:54 AM
hi, im using Archicad 21, and i have created a Composite wall which we use to document, it has a solid fill to the inner stud wall. a ventilation cavity which has no fill and an external brick wall with brick hatch. is there a way that i can turn off the hatch for the external brick wall and internal stud wall on certain layers (ie. Bracing layer and Slab Plans layer) so for example on a Bracing Plan my internal and external walls dont have hatch/fill shown on them. We want the fill to show on the floor plan layer just not on some other layers
and if this is possible, is it also possible to alter the walls lines from solid to dashed on the above mentioned layers?
Thank you so much!
Solved! Go to Solution.
2022-04-25 09:35 AM
A correctly set up Graphic Override should do the trick.
Make sure you specify the exact elements that you want to change the appearance of and have a fill override to make them transparent and lines dashed. You can do this within one single rule or you can set up multiple rules for added flexibility down the line.
Then make sure your GO Combination is applied the Bracing Plan.
2022-04-25 09:37 AM
thank you, i will try and work it out, much appreciated!
2022-04-25 09:58 AM
thank you so much, got it working, much appreciated
2022-04-26 02:12 PM
Just one additional piece of info: Graphic Overrides always modify the representation of the whole element. They can not be set to override only specific skins of a Composite. This is something that is on the wishlist.
