Convert 8 to 18
Migel
Please.
How can I read AC 8 file wit AC 18?
mikas
You don't say your OS or OS version.
But still, you can check it all out from here:
https://community.graphisoft.com/t5/Setup-License-articles/Archicad-file-and-protection-compatibilit...
and download the necessary converters from here:
https://graphisoft.com/downloads/fileconverter
On a Mac it's more complicated than on Win because of (un)compatible OS versions you might need.
AC27, Rhino7/8+Grasshopper, TwinMotionMac Pro 6,1 E5-1650v2-3,5GHz/128GB/eGPU:6800XT/11.6.5 • HP Z4/Xeon W-2195/256GB/RTX4080FE 16GB/W11ProWS
As mikas showed - you can open an AC 8.1 file without any problems (other than missing library parts if the file is not a PLA).  Hopefully, your file is an 8.1 file rather than 8.0 (8.0 was a super buggy version that was quickly replaced with 8.1) so that it should just open.
If you need the file converter, then using a Windows machine (or borrowing one from someone temporarily) is the only solution  - unless you have an ancient Mac with a 32 bit OS laying around.
AC 28 USA and earlier   •   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
