Dimension Tool
Karol Lozinski
I have an issue with dimension tool. Nothing big, but it bothers me a little and I don't know how to turn it off nor I have a memory how have I turn it on. I'm talking about a frame around numbers. Can someone tell me what is it?
Also, when I try to measure the height of landing using Level Dimension Tool it doesn't do it's job. Instead it shows me the height of a Level 0. I have no idea how to make it work 😕
AC 23 HP Omen Win 10
5 REPLIES 5
David Maudlin
Those are selection points for the dimension text, they do not print, they can be hidden by toggling the Textbox Handles command.
The Level Dimension Tool uses Gravity to be associated with an element (Slab, Roof, Mesh or Shell).
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC26 USA • iMac 27" 4.0GHz Quad-core i7 | 24 gb ram • MacBook Pro 2.8GHz | 16 gb ram • OSX10.15.7
Karol Lozinski
Thanks for help with Textbook Handles! Thats exactly what I was looking for!
But the problem with Level Dimension Tool remains 😕 Although I use gravity for slabs I'm unable to measure height of stairs made with slabs. Here are screens. Any ideas?
Karol Lozinski
Here's one of slabs in the middle
Erwin Edel
The slab should highlight when you are using gravity and level dimension, if it's not doing that, you are dimensioning something else.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Karol Lozinski
Yes! That was the thing. Sorry to post dumb question... I'm just a beginner but I really appreciate quick and good help!
Cheers!
