Dimension and Renovation Filter
dhnguyen
I have been able to create dimensions just fine in my existing/renovation plan.
Recently I have been getting this message every time I try to create a dimension in my Existing / Demolition plan. I check my renovation status and I dont see any option for dimension... how do I get rid of this message and be able to draw dimension in my existing plan again?
DNguyen
ArchiCAD 18- 25
(expert in AutoCAD, novice in ArchiCAD)
5 REPLIES 5
David Maudlin
DNguyen:
Show the Renovation palette and check the Renovation Status of a visible dimension string, set the Renovation Status to that same status.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
dhnguyen
Is this what you are referring to? This option is greyed out and I can't seem to ungrey it.
- In my demolition plan renovation filter, the "Annotation Elements" is checked off.
DNguyen
ArchiCAD 18- 25
James B
dhnguyen wrote:
Is this what you are referring to? This option is greyed out and I can't seem to ungrey it...
They're greyed out, because nothing is set to be overridden. Only hide/show.
Once one of the renovation status is set to be overridden, they become enabled.
James Badcock
Graphisoft Senior Product Manager
David Maudlin
No, the Renovation palette is where the Renovation Status of an element is set.
dhnguyen
I see, thank you. I never used the Renovation Palette before, not sure how it got to it that way to begin with. I opened the Palette and changed the Renovation Filter, I got it to work now, thank you! I kept on checking the model view option and the renovation filter to make sure it was on the same settings and I didn't understand why it wasn't working earlier.
DNguyen
ArchiCAD 18- 25
