Door Schedule Question
g r a n t
Hello. I hope this is an easy answer. I'm still a rookie with Archicad 25. I am looking to set up a door schedule. I've started with the built-in schedule. The built-in schedule seems to grab all doors in the library vs. just in the model. I can't find a criteria or field that allows me to select only "in model" doors. Maybe I just don't know the correct nomenclature for the search criteria. Can anybody help push me in the right direction? Thank you. Grant
I started learning ArchiCAD at age 50....bear with me,
AC28
MacBook Pro M1 Max.
Sequoia 15.4
Schedules will only schedule what is in the model, not what is in the library.
If you select one of the doors in the schedule, you will see some buttons at the top of the schedule that should allow you to show and select the door in plan or 3D so you can see where it is.
HI. I'll look into this soon. Thank you. G.
AC28
MacBook Pro M1 Max.
Sequoia 15.4
