Read more
Doorframe size and wallopening
Dontknow
Hi there,
With which setting do I achive this story-view of my doorframe in the wall?
So I've got a wallopening of 1016 mm. and a doorframe of 1034 mm.
wallopening
Greetings
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
5 REPLIES 5
Hi @Dontknow , on the view right click and go to view settings then go to 2D/3D Documents section and feel happy to change dimensioning system.
AC 27 INT 5003/WIN 11
Dontknow
No, it's not about the dimensioning system.
How do I place a doorframe with a width off 1034 mm which gives a wallopening of 1016 mm.
ArchiCAD 25.
I think this screenshot can help you get the desired result, these settings are almost  the same for doors and windows.
Why has this post been split?
Could you just work with a Casing? Not sure how those dimension...
I was wondering that myself.
I assume one of the moderators went to move the post but moved a reply instead of the whole post.
I have merged back together and moved to whole post to document & visualise.
