Edge material prioritized over outside surface material
DangCad
In my model, there is one corner where the edge surface material is visible instead, and I can't figure out why. See screenshots below, two where the walls selected if it helps.
DangCad,
I have edited this post to show your images.
Rather than saving as JPG files and attaching, simply copy and paste the screen shot directly into the post.
That way readers don't have to open the images.
Barry - moderator.
undefinedundefinedundefined
Archicad 19 | Windows 10 Home | Intel(R) Core(TM) i7-4710HQ CPU @ 2.50GHz | 16 GB RAM
Rico
You need to select this option:
I don't remember what it is in english but it should be self-explanatory.
Rico 
iMac 27" 5K • macOS 10.15.7 Catalina • 40GB RAM | ArchiCAD 24 5004 FRA
Ryzen Threadripper 3970X • Windows 10 • 64GB RAM | ArchiCAD 24 Solo UKI
Rico
Rico 
Perfect! That solved it, never seen that option before. Thanks!
