Existing & Proposed ...
Eman
Hi, Let's say I have one existing ground floor drawing and one proposed ground floor drawing and I want to put them one on each other. Usually I copy the proposed drawing and paste it on the existing drawing. But which is the best way to do it? Because if I find a mistake after copying one on each other then I have to restart again by opening the previous file to fix the mistake and then I copy and paste again and I am sure this is not the right way to do it.
Thanks in advance.
Eman / Draftsman
Works at an Architects Company using ArchiCad 21
Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz 3.19 GHz, 8.00 GB, 64-bit operating system, x64-based processor
10 REPLIES 10
You need to set the criteria so it searches only for those walls that you want to override.
So with the 2 criteria as shown in you image (Element type is wall and Renovation status is As Built to Sanction) that should only select walls with that particular renovation status.
You can add more criteria to include/exclude certain elements.
The criteria filters in or out the elements you want to override.
