Read more
Exterior walls not showing up in elevation
dhnguyen
I can see my exterior walls in the floor plan. However, when I go to 3D view or 2D views, they're not showing up. The walls are set to existing layer renovation style, so I'm not sure why they're not showing up.
The windows are there though.
DNguyen
ArchiCAD 18- 25
(expert in AutoCAD, novice in ArchiCAD)
4 REPLIES 4
Select your roof and cancel the relation between roof and the wall
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
dhnguyen
Okay, i see it now, thank you.
DNguyen
ArchiCAD 18- 25
Guru
When using the "Trim Elements to Roof" function, everything outside the bounds of the roof is clipped rather than just what is above / below the selected plane.
Ling.
dhnguyen
I see it now, thanks. I moved the aligned the solid line to the outside of the exterior wall and now my wall is showing up again. Thanks.
DNguyen
ArchiCAD 18- 25
