Find and select an object or element that has an associated label?
Is there a way to find and select objects or elements that have an associative label attached to them?
I know you can find and select labels that are associative, but I want to select those objects and not the labels.
Thanks in advance...
AC27 USA - build 5003
HP ZBook 15 G6
Intel(R) Core(TM) i7-9850H CPU @ 2.60GHz, 16GB RAM
Windows 10 Pro
I can see no way to do this directly within Archicad.
Unless someone else has an idea, the only other thing I can think of is to have an add-on created.
Maybe that can determine elements with/without associated labels - but I am not sure if even that can be done.
I actually have the same question. Are there any properties of label indicate the associated element name/Id? Or which API can expose the correlation between label and element?
