Floor Plan Display: Hidden Part of Stair Tread
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2023-09-13
08:48 AM
2023-09-17
08:41 PM
I'm trying to display the hidden part of the Stair Tread as per the attached images.
I have tried a number of combinations of options in the Stair Selection Settings and also the Model View Options, with no success.
I'm quite sure I've seen this line displayed in my own projects before (and have battled to hide it). There is an example at the Archicad help center that shows the line I am talking about (also refer attached image).
Does anyone have any guidance to offer?
Thanks
AC23–26 3001 NZE | i511400F | 32GB | GTX1650
Solved! Go to Solution.
- Labels:
Model View Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-09-14 04:56 PM
Hi Paul,
IIUC you may need to adjust Tread noising option via MVO as illustrated in this video:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-09-13 09:58 AM
Try grid fill to none in MVO settings
Archicad 26, build 3001
Montenegro
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-09-13 08:43 PM
Thank you for your thoughts.
This is one of the options I have tried, to no avail. Does it work for you? Perhaps it is a clue as to why mine isn't working...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-09-13 09:41 PM
Hi Paul
Is this perhaps what you are after?
GRAPHISOFT Certified BIM Manager | Senior BIM Specialist | LinkedIn
ARCHICAD 18-28 | BIMcloud | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
Australia & New Zealand
Windows 11 Business | Intel Core i9-13950HX @2.2GHZ | 64Gb RAM | 2x Samsung S27F350 1920x1080 60Hz | Nvidia RTX 4000 Ada Generation Laptop GPU (12Gb)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-09-13 10:21 PM
Thank you for your thoughts. What you've shown is not quite what I'm after; the attached image shows the result I'm hoping to see (I've used the Non-Slip Accessory from the Tread Accessories and tweaked the settings so that it lines up with the start of each riser):
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-09-14 04:56 PM
Hi Paul,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-09-17 11:35 PM
This is the solution, thank you.
Part of my problem is that I was using the Built-In Stair Grid, which does not have the options for Tread Nosing line types. Thanks to your helpful video I could see that I needed to be using Stair Grid 25 (I am using AC25 for this project):
